Hi everyone.
I managed to modify some parts of fritzing. Now I would like to move on to something more advanced on two levels (top and bottom pcb side). The part I want to do is this. Below I upload three images: the first two of the component, the last of the pcb (the dimensions are correct). Can you suggest me on the PCB component side how can I tell Fritzing that a pin is in the top part rather than in the bottom part?
Can you suggest me a database part that implements this feature (top & bottom PCB)?
Sorry for the late reply, my Internet link is mostly broken until I can arrange an upgrade. This is a standard DB9 connector that connects via wires and is on core parts. Do a parts search for “DB 9” and you will find it. If you have a SMD version that needs odd pads this howto explains how to achieve that:
Internet link willing I will answer questions about the howto.
Is there a fritzing part that implements, for example, weldable pads above and below? Or someting similar? (I could open it and understand how to do it).
