So I’ve come to find that the Pi I’m using needs 1.8A, but the TSR 1-2450 is only rated for 1A.
This fellow though does 2A, it’s pinout seems identical to the TSR 1-2450 but the footprint is a bit bigger, so could you please alter the TSR 1 to make this part please?
RS Part: https://uk.rs-online.com/web/p/products/9068487/
DataSheet: https://docs.rs-online.com/402c/0900766b816eda0f.pdf
Sorry for being such a burden!
Blue
May 13, 2020, 1:55pm
2
I edited little, the TSR 1 part, made by vaneapp…
See if it works…
TSR-2-Series.fzpz (4.9 KB)
Thank you! I’ll give it a go
Ah, I think it needs a new ID, as fritzing isn’t letting me import that as it says there’s already a part with that ID
Blue
May 14, 2020, 2:19am
5
That not suppose to happen… I already renamed all the IDs…
Anyway, try this one…
TSR2 Series.fzpz (5.0 KB)
As you probably discovered the moduleId wasn’t updated and thus the conflict. As well in the latest version the description needs some updates too:
Mini DC/DC Step-Down (Buck) Converter - 5V @ 1A output - TSR12450
should change to
Mini DC/DC Step-Down (Buck) Converter - 5V @2A output - TSR 2-2450
to match the new part.
Blue
May 14, 2020, 8:19am
7
Yes, I missed the description in hurry…!!
Hey guys, that looks good to me, thanks!
