Parts request illuminated button
I would like to use this illuminated button in some projects. At mouser they call it Pushbutton Switches Top actuated Keyswitch illuminated, SPST, THT, 1.30N, 1211.412.8,
https://www.mouser.be/datasheet/2/240/d6-3050860.pdf
https://www.mouser.be/ProductDetail/CK/D6RLWHF1-LFS?qs=zW32dvEIR3sjlW79DNUOCw%3D%3D
Is there a braveheart that can do to this for me please?
Thanks
It looks like this one that I did a while back should work for this.
Yes, that is correct but realised now it is another one I need :joy:
It is a bit smaller, but don’t know if the footprint will work.
Switch: keypad; Pos: 2; DPST-NO; 0.05A/12VDC; colourless; LED; white
Manufacturer part number:
PB6149L-5
TME Symbol:PB6149L-5
You are correct this is just different enough to be annoying and require a new part. This part should match this.
edit Nov 11 2024
replace part with a corrected one with the proper footprint.
pb149l-5.fzpz (4.9 KB)
On the up side, this is a more commonly used part :slight_smile: I needed one of those, too! Thanks!
Hi Peter,
For another project I need to use this RGB switch. And so we keep 3 different switches in one topic :slight_smile:
https://www.mouser.be/ProductDetail/Well-Buying/TC002-N11AS2XT-RGB?qs=ZPkwNW6XKpqkg90DPui15g%3D%3D&srsltid=AfmBOop6rcSl0iy5qVnLOGhgfEj9y0d8UVC-mnTkj197cQP3iFzzDI-z
https://www.mouser.be/datasheet/2/435/Well_Buying_107_TC2N11AS2XTRGB_Spec-3499160.pdf
Is it possible to create this part please?
Kind Regards
tc002-n11axxx-r-g-b.fzpz (5.8 KB)
Hi Peter,
you are a the best!
Thank you
Take care
G
Hello Peter,
There is an error in this pb149l-5.fzpz
pins 1 and 2 (also 3 and 4) are indeed connected but the footprint is wrong. The diode is also wrong and must be switched.
I made some printscreens and info to have the correct part please.
Hope you can help me out.
Take care,
Gregory
OK the original part has been replaced with a corrected one. You will need to delete the original part from your mine parts bin, then shutdown and restart Fritzing (to really delete the part) before it will let you load the new one.
