Parts Request ESP32 Dev Board with Relay/WiFI
Hi Everyone,
I am looking for a part for an AC 90-250V ESP32 Single Relay Development Board with Onboard ESP32-WROOM-32E Module. I want to do some home control stuff. Like this board.
Anyone know where I can get it for my Fritzing parts bin? Thanks.
ESP32-Wifi-Control-Module
I got it at AliExpress.
This part should do what you want. Note if you put this on a pcb (which is possible) it would be advised to not run traces too near the relay pins (which don’t appear in pcb) as they have power line connected to them and may jump across to nearby traces.
ESP32-Single-Relay-Development-Board.fzpz (37.2 KB)
That’s perfect! Thank you.
I am looking for the 4 Channel Relay variant of this Board.
4-Channel Variant:
4 Channel @ Aliexpress.
Should be possible if there is enough documentation. It will be up in a while.
This board should do what you want. The first warning presumably doesn’t apply to you as you supplied the web site I used to make this and presumably the board you have is from them, but for later people looking to use this there are at least two different pin layouts available for this board and this part only matches one of them. So you need to make sure the part matches the board you have. The next warnings apply to everyone. The images are lousy (low resolution and/or blurry) so the pin names may be wrong. Please verify the pin names match the board you have (always a good practice anyway.) As well the screw terminals don’t appear in pcb as you can’t connect to them from pcb. They do appear in breadboard and schematic as they should.
ESP32-4-channel-Relay-Development-Board.fzpz (54.6 KB)
It works for me. Thank you very much. Very quick response :slight_smile:
