Other (please specifiy) - CC1101 xxxMHz Module (868 in my case)
Unsure - check links to PDF above
Not been able to find a fritzing part for this already so hoping one the great part makers might be able to create this at some point. (Since I’ve established a few times I’m useless at making parts! ha)
This part may do what you want. It will be necessary to print out the pcb footprint at 1:1 scale and compare it to a real part because there data sheet is 1ncorrect in the pcb layout measurements Here the copper layer is laid out according to their measurements (which add up to ~18.5mm on the height which is listed at 20.0mm) but it doesn’t match the image.
