Parts location in Fritzing
Please help me with some advice. I have fritzing installed on my computer and in a separate folder several parts. Where should I copy in the application ( folder ) these parts to see them in the application ?
If you load the parts either by double clicking on the file or via File->open->file_name they will appear in the mine parts bin. If you choose to save the loaded parts when you exit Fritzing they will be added to the mine parts bin until you delete them.
I want to copy directly because i have 200 parts. Manual is not a solution. This can be done ?
Loading the parts is going to be the easiest solution. The bin storage format is not .fzpz format so you would need to unzip all 200 parts and move them (carefully and correctly!) in to the appropriate place with correctly modified file names. It is going to be much easier and much more error free to load the parts via Fritzing (where Fritzing deals with unpacking and placing the parts) and save the bin. It is possible to do this manually as long as you know the bin format but in my opinion it isn’t worth the work.
