The Part DRV8825 is in fritzing but does not show. How do I get the part
In this case because it is in core parts, a search in the parts search bar will find it.
If that hadn’t worked a google search of the form “fritzing part drv8825” would find any part on the net (including in the forum, where the forum search bar will also find it.) Be aware that parts from the net may not work correctly. If you find one that doesn’t work, post here and one of us will likely fix the part for you.
Thank you Peter, The search worked, it was in a bin called temp. In fact it was the only thing in temp.
That means it was in a .fzz file (a sketch.) Any part not in core parts will be exported as part of the .fzz file and placed in the temp parts bin as long as the .fzz is loaded (but will go away when the sketch is closed unless you move it to the mine parts bin and save the bin.)
Thank you again Peter. In my stumbling around I did bring in a fzz file from somewhere and probably saved everything. I’ll move it into “mine”.
