Hello, Can someone please make a part out of the ARD Sen Pressure, you can see in the picture. I just need ground, voltage and sensor pin.
Pictures are basically useless for making parts. The template you appear to have ignored is there to try and get the information needed to make a part. In this case that is this web site
which does have enough information to make a part (i.e. the physical dimensions of the board which are sort of there and the connections.) As a result this part should do what you want.
joy-it-SEN-Pressure10.fzpz (27.9 KB)
This is awesome !Thank you so much!! Ok for the next time, now I know what to do.
Lucas
