Part Request Raspberry Pi module 3 Wide Angle
Raspberry Pi module 3 Wide Angel
(https://www.robotistan.com/raspberry-pi-3-genis-kamera)
https://octopart.com/datasheet/cm3%2B%2F16gb-raspberry+pi-98770584?gad_source=1&gbraid=0AAAAAqOfdgpKRZldPTWYLyZe7HKgBiRpy&gclid=Cj0KCQjw2ZfABhDBARIsAHFTxGzIppo7voQmO98ro96nkXYzmu5ukMwXxylYazI7enjSEvSlginFbnQaAo5CEALw_wcB
@SMmahOOr Okay, another solution: right-click and download the SVG
svg.breadboard.rasberrypiniorcamerawithribbon2_8d9845d7a744ee0f7c425a76d29d9729_1_breadboard
Drag out the raspberry pi
then drag out the bradboardImage part…
…load image file → open the file and plant it on the RPi
