Part Request: Pimoroni PicoVision
Pimoroni PicoVision
Previous work, similar parts
I cannot find any similar works
I extracted this:
picovision_diagram
from this pdf:
picovision_diagram
PicoVision (Pico W Aboard)
and their schematic here:
picovision.sch
N/A
This part should do what you want with the following cautions: the mounting holes are only on silkscreen and are not drilled by default. If you want the mounting holes you need to drag the pcb hole part from core parts in to your sketch, place it over the hole in silkscreen then set the size appropriately. Before ordering pcbs print the pcb footprint out at 1:1 scale (the default) and compare it to a real board. There is no mechanical drawings that I can find so the pads were placed from a jpeg image and thus may be in the wrong place. As well the grove connector does not appear in pcb as it has no connection from pcb view.
Pimoroni-PicoVision.fzpz (54.5 KB)
Hi Peter,
Thank you for doing this and with such haste.
The Grove connector is not an issue, its great that you have it in the breadboard view. I will take your cautions under advisement though. This will really help with prototyping the layout though. Thank you very much.
Graham
