Looking for a fritzing part for the following Pimoroni Breakout board the Pico Audio Pack.
Creating schematics for the project and currently working with the relevant components on the board, the DAC and stereo headphone amp. Would be very useful if someone had already created the .fzpz or could point me in the right direction. Haven’t been able to find Eagle files for this either I’m afraid.
Pimoroni Pico Audio Pack
Have you done a Google Search of the part
Yes, not found however.
Previous work, similar parts
The PicoVision from Pimoroni is a similar part:
Pimoroni-PicoVision.fzpz (54.5 KB)
This is the best quality image I can find of the part.
Audio Pack Diagram
Seems to be a higher resolution version of their diagram on the Pimoroni site:
pimoroni pico audio site
Pimoroni Pico Audio Page
and their schematic here:
PicoAudio.sch
- I did not read this
- Breakout board, sub assembly, plug in module (A)
- Antenna (AE)
- Battery (BT)
- Capacitor (C)
- Diode (D)
- Display (DS)
- Fuse (F)
- Hardware , mounting screws, etc. (H)
- Jack, fixed part of a connector pair, header (J)
- Relay (K)
- Inductor, Coil, Ferrite bead (L)
- Loudspeaker, Buzzer (LS)
- Motor (M)
- Microphone (MK)
- Plug, moveable part of a connector pair (P)
- Transistor (Q)
- Resistor (R)
- Thermistor (RT)
- Varistor (RV)
- Switch (S)
- Transformer (T)
- Integrated Circuit (IC)
- Crystal, Oscillator (Y)
- Zender diode (Z)
- Other (please specifiy)
N/A
