Battery BASHING LiPo 5000mA 11.1V
Can someone make this battery for me?
Link is same as the image, I just put it if someone want to see more details.
Check this other link: https://www.rtrvalladolid.es/inicio/-9695bateria-lipo-bashing-5000mah-111v-3s1p-60c-ec5-gensace.html
While a new part could be created, the LIPO battery in core parts will do as well as it is electrically identical. There are an infinite number of these batteries and we will go nuts if we try and create parts for them all. I would advise using the battery in core parts.
True, unless he wants the 4-pin JST Connector (circled in green)
Then it’ll be a problem (as most websites don’t mention what the connectors are!)
It is not necessary. In real life I have just used that connector for check how charge is the battery
Oh ok, then just use the the LIPO Bat in core parts.
The problem is the 5000 mA and 3S
Lithium Ion Polymer Battery 11.1v 5000mah.fzpz (6.8 KB)
This is the part you should want.
Thank you so much! That is what I was looking for
