Part Request : Grove Universal 4 pin connector
Previous work, similar parts
Hello, I’m new and a beginner, I’m looking for this connector, I couldn’t find anything with a pin spacing of 2mm in the existing parts. I wasn’t able to redraw an existing part.
A google search of the form “fritzing part grove 4 pos 2mm connector” turns up this part which may do what you want (you would need to check the part is correct though!)
Thanks Peter, that’s what I wanted!
