Part Request: Electromagnet with Iron Core
Hey, I can not find an electromagnet in the part library. Could someone please create/share this part. Would not to be something complicated just a cylinder with two wires at the bottom. The schematic symbol is the one from an inductor with two solid lines next to it.
Thanks for the support.
A google search for “fritzing part electromagnet” turns up a variety of hits one of which may do you.
Unfortunately I could only find a door lock and a product from grove.
There is one in core parts, it is just hard to find (solenoid doesn’t come up, electromagnet does although both appear to be in the tags):
found from this hit on the google search
https://fritzing.org/projects/arduino-controlled-solenoid
