Anyone knows where a CR2032 vertical battery holder pcb footprint/schematic (exclusively for download and use in fritzing) can be found and used?
Assuming I guessed the connections correctly (center pin +, two outside pins -) this part should do what you want. As always before ordering boards print the pcb footprint out at 1:1 scale and compare it to a real part (as I don’t have one!)
battery-holder-cr2032-vertical.fzpz (4.1 KB)
