Part Request CNC controller
Hi I’m new to this enviroment. I need help with creating CNC controller MyPlasm CNC by proma.
Here is specitfication:
Power supply for the controller: 24V DC ( 22 - 26V DC)
Maximum current consumption : 0.6A ( 600mA )
Number of axes : 4
Motor driver output signals : TTL 5V STEP (PUL) / DIR 40mA
Motor frequency: 0.02 - 250kHz
Limit sensor inputs ( 8 x 24V ) : NPN NO, NPN NC, Contacts,
active state : LOW
Dimensions of CNC Controller : 120 x 100 x 15 [mm].
Measuring voltage ARC / THC max : 300V DC ( test 1000V DC )
 HF / HV protection : 10kV AC ( 15kV AC test )
 Optical isolation : 2 x 3kV
 PC communication : USB
 Plasma Interface Communication : RS485
 Optional outputs ( 2 ) : OC 0.5A 5-30V
producent site:
Download page - Proma-Elektronika Manuals
[X ] Other (please specifiy)
Not enough information to do anything with. We would require the web site for the device with physical dimensions and connection information to make a part.
Sure, I’ve added more information is it enough?
Yes probably. It will likely take a while as I am busy though.
Of course. Thank you very much
MyPlasm-CNC.fzpz (31.2 KB)
Once again Thank you very much, I only need that part to make circut visualization so its perfect. Have a Nice day
