Good morning, has someone developed this part?
In case not could someone develod it?
This is the pin out
Pin 1: GND
Pin 2: VCC
Pin 3: N.C.
Pin 4: LCD_RS
Pin 5: LCD_WR
Pin 6: LCD_RD
Pin 7: LCD_DB8
Pin 8: LCD_DB9
Pin 9: LCD_DB10
Pin 10: LCD_DB11
Pin 11: LCD_DB12
Pin 12: LCD_DB13
Pin 13: LCD_DB14
Pin 14: LCD_DB15
Pin 15: LCD_CS
Pin 16: F_CS
Pin 17: LCD_RESET
Pin 18: N.C.
Pin 19: LED_A
Pin 20: N.C.
Pin 21: LCD_DB0
Pin 22: LCD_DB1
Pin 23: LCD_DB2
Pin 24: LCD_DB3
Pin 25: LCD_DB4
Pin 26: LCD_DB5
Pin 27: LCD_DB6
Pin 28: LCD_DB7
Pin 29: TouchP_CLK
Pin 30: TouchP _CS
Pin 31: TouchP _DIN
Pin 32: N.C.
Pin 33: TouchP _DOUT
Pin 34: TouchP _Penirq
Pin 35: SD_DOUT
Pin 36: SD_CLK
Pin 37: SD_DIN
Pin 38: SD_CS
Pin 39: N.C.
Pin 40: N.C.
And i attach an image with the dimensions
Thanks and regards
Andrea
