Hello, could someone help me with the part 74HC244 with Dil16 case.
thanks a lot
thanks a lot
The 244 is a 20 pin chip as far as I know it doesn’t come in DIL16. As noted a generic IC will do what you want. Select it and drag it in to a sketch set it to 20 pin DIP and then use edit pin labels tab in inspector to name the various pins to match the 244. The alternative is to make a custom part but no one appears to have done so yet.
