I have a question—probably a silly one.
I’m working on a PCB design for a small project for the first time.
I ordered these cables to connect additional components.
However, I can’t find a suitable part for them in Fritzing.
Could someone give me a tip on what I should use here?
With best regards
Hagen
There are some pin headers that you might be able to use. However, I don’t think there is a connector that you can use to make a connection with them.
You need to attach the cables directly to the pin header. Here’s an example:
Beispiel.fzz (2.3 KB)
If you click on the component, you can also adjust many properties of the socket in the bottom right of the window.
Best regards, Harald!
