[Part] Electrokit EKM047 USB-C PD trigger (5 / 9 / 12 / 20 V)
Hi all,
I made Fritzing parts for the EKM047 PD-Trigger Mini USB-C board, sold by Electrokit, a Swedish electronics shop (art. no. 41038328), in case anyone else wants to use it in their sketches.
Product page (Electrokit, in Swedish): https://www.electrokit.com/stromforsorjningskort-pd-trigger-mini-usb-c-5-20v
The board negotiates a voltage from a USB Power Delivery charger. The output voltage (5 V default, 9 V, 12 V or 20 V) is set with three solder bridges on the back, so I made one part per setting. That way the breadboard, schematic and PCB views match how the board is actually configured.
What’s included:
  • 4 parts: PD-Trigger Mini USB-C (EKM047) 5V / 9V / 12V / 20V
  • Breadboard, schematic, PCB and icon views for each
  • Connectors: GND, GND 2, VOUT, VOUT 2 (each pair is bused, 2.54 mm pitch)
  • Pinout and solder-bridge table in the docs
Install: download the .fzpz from the repo and open it in Fritzing, then search for “EKM047” or “PD-Trigger”.
A few notes:
  • Board specs: 15-60 W PD power, 15 x 10 x 4.9 mm.
  • If your charger doesn’t support the selected voltage/current, it falls back to a lower one (a board set to 20 V can end up at 12 V or 15 V). Always measure the output before connecting your device.
  • Pad positions and the PCB footprint are as drawn, not measured on a real board, so check them before milling or ordering a PCB.
  • This is a custom part, not an official Fritzing or Electrokit part.
Repo: https://github.com/mhed89/electrokit-usb-c-pd-fritzing
License: Beerware, use it however you like.
Feedback and corrections are very welcome, especially if you spot anything wrong in the footprint.
Markus
