jpjoao
April 10, 2025, 11:18am
1
I’ve already seen this part used in fritzing projects but i cant find it for download, thought maybe someone has it. Thanks!
Panasonic sn-gcja5
https://api.pim.na.industrial.panasonic.com/file_stream/main/fileversion/244939
vanepp
April 10, 2025, 2:20pm
2
There doesn’t appear to be a part for this particular device, but a google search of the form “fritzing part particle sensor” turns up a variety of other parts one of which may be what you used.
It is there somewhere, as the element14 community uses the same part
jpjoao
April 10, 2025, 2:39pm
4
yeah i saw those! but i dont know if that person made the part and never published it
vanepp
April 10, 2025, 3:17pm
5
The image isn’t a Fritzing part. It is a header superimposed on an image of the sensor not a part.
This sensor should do what you want. The order of the connectors isn’t correct but the connections are all there.
a new part could be made but it probably isn’t worth the effort.
jpjoao
April 10, 2025, 4:19pm
6
“It is a header superimposed on an image of the sensor not a part.”
This actually solved my problem as I was able to replicate it.
Thanks a lot!
Juphil
April 17, 2025, 9:33am
7
Hi
The right object Panasonic is SN-GCJA5
A data sheet can be downloaded from mouser.de - just ask in google for Panasonic feinstaubsensor mit Modul.
the part SN-GCJA5 is the real laser-sensor - the part on the left must be Arduino specific from xenon just to give power to the Panasonic and transfer data
Regards
J. Philipp
Juphil
April 17, 2025, 9:36am
8
panasonic_08262019_Sensor_Laser_Particulate_Matter-1628325.pdf
I just tried to include the above named pdf and had to learn that this may not be done ???
J. Philipp
Juphil
April 17, 2025, 9:44am
9
Left side is deprecated part to be found under particle mesh- finished year 2020-
try to use https docs.particle.io and there under xenon etc
