I’m trying to layout my first PCB in Fritzing. When running a DRC on this design, I get overlap errors, although both wires are on different sides of the PCB and the layout should be ok… Do you have any ideas?
Looks like there is a problem with your .fzz file upload. It has no traces and no DRC errors. That said, if you click on a line in the DRC report it should select the trace that it is complaining about (although with overlaps, that can mean an error in a part as well.) The best bet is to upload a .fzz which shows the problem and we can go from there.
