Other spacing than 0.1in for bend points
I am running into an issue when using the PCB view.
I am using parts with pin spacing other than 0.1in (2.54mm), e.g. 0.05in (1.27mm). (The part is actually an SO16 IC).
When using parts with lower pin spacing, how is it possible to use the given spacing for bend points?
It seems, bend points can only be created at the 0.1in (2.54mm) grid.
How can this be changed, so bend points can be created at other spacings?
Regards,
Max
Nevermind, I figured it out:
In PCB view, it is View / Set grid size (in the menu).
