Omron E6B2-CWZ6C Incremental encoder
Hi, y’all, I hope u R cool.
I need Omron E6B2-CWZ6C encoder, but i couldn’t find it, if anyone would help please.
THANKSSSS.
Hi @youssef_Ahmed Please fill up this template
*Please edit this message to let us know exactly what electronic part we are talking about. Creating parts is some work, so please be considerate and make it easy for us.*
*We need the title, an image and the technical data, fields are marked with a ❗ . Without this infomation, the part **can not be created**.*
*Search the part prepare before posting.*
*You can search for the part here:*
* *🔎 Top right here on this page*
* *🔎 Top right in Fritzing Application*
* *With the search form on fritzing.org (“Go” in the top right area)*
* *Appending the terms “fritzing part” in your favorite search engine*
**Name of the part❗**
**Your previous work, similar parts**
**Top view❗**
<This picture shows the part from above, so that is easy to see were connectors should go, and which diameter they have.>
Copy and paste a foto or vector graphic. *No links here, otherwise your post might be flagged as spam.*
**Datasheet❗**
Please add a link to PDF of the manufacturers datasheet. *Here, a link is fine.*
**Footprint**
**Type**
[x] I did not read this
[ ] Breakout board, sub assembly, plug in module (A)
[ ] Antenna (AE)
[ ] Battery (BT)
[ ] Capacitor (C)
[ ] Diode (D)
[ ] Display (DS)
[ ] Fuse (F)
[ ] Hardware , mounting screws, etc. (H)
[ ] Jack, fixed part of a connector pair, header (J)
[ ] Relay (K)
[ ] Inductor, Coil, Ferrite bead (L)
[ ] Loudspeaker, Buzzer (LS)
[ ] Motor (M)
[ ] Microphone (MK)
[ ] Plug, moveable part of a connector pair (P)
[ ] Transistor (Q)
[ ] Resistor (R)
[ ] Thermistor (RT)
[ ] Varistor (RV)
[ ] Switch (S)
[ ] Transformer (T)
[ ] Integrated Circuit (IC)
[ ] Crystal, Oscillator (Y)
[ ] Zender diode (Z)
[ ] Other (please specifiy)
