I’m looking for a part file of the Olimex ESP32-POE-ISO board. Has anyone ever designed or found this?
Regards
This part should do what you want. Note neither the battery connections (on a connector) nor ext1 (connector) appear in pcb as they aren’t accessible from pcb and the mounting holes are by default not drilled. If you want them drilled you need to drag a hole from core parts/pcb over the hole in silkscreen and set the size appropriately.
olimex-ESP32-POE-ISO.fzpz (28.7 KB)
