I’ve just buy this breadboard RPi Proto Kit Breadboard PCB pour Raspberry Pi and I want to know If someone has already create this parts.
Thanks a lot to your response.
Don’t see such a part. Adafruit has something similar (but with the header in a different place) so you might want to see if they have a part for that in their Fritzing repository. Should be reasonably easy (as easy as making parts ever gets anyway ) to make one starting from one of the existing perfboard patterns I expect. I assume you only want breadboard view for documenting?
