Strange, I’ll try again tomorrow and let you know, thanks again
Please post a screen shot of the error message (or the failure if there isn’t an error message) so I can see what may be going wrong.
hello,
I tried to import the NRF24L01-BOv2.0-fixed.fzpz file again, it appears fine in MINE. If I move it to “Schematic View” and create a circuit, the component does not appear in “printed circuit”…
That is because that version doesn’t have pcb view. If you want pcb you need to use this one:
NRF24L01-BO-with-pcb.fzpz
which is a post or 2 below the first one (someone else wanted pcb view.)
Although I’m not entirely sure the pcb version will work. You would need to remove the headers in order to be able to solder it to the pcb.
thanks for answer but the file NRF24L01-BO-with-pcb.fzpz is not the good one.
it’s not with extern antenna :
i want this one ![]()
replace with an updated pcb view.
NRF24L01-BOv2.0-with-pcb.fzpz (25.2 KB)
Hello !!
Perfect !!! ![]()
Thanks a lot !!
hi!! Damn, a little problem, in “printed circuit” we don’t see the entire module, we only see the adapter…
Thanks again
The adapter is all that appears on the pcb. The Nrf24l01 plugs in to the adapter and doesn’t appear in pcb. As noted you would need to unsolder the headers on the adapter to mount it on the pcb so I don’t think this is too useful.
thanks very much, i really need to see the NRF24l01 in “printed circuit” to place the component on the PCB…
Can you modify to see the adaptater and the NRF24l01 and screwnof antenna too together on PCB to see how to place it on?
thanks a lot
Hi! I need a part of nrf24l01 + pa/lna without adapter, but I couldn’t find it(
There is a nrf24l01 in core parts, as well a google search of the form “fritzing part nrf24l01” will usually find any other parts available on the net. Other than that we would need a web site of the board you want.
Thanks, but on the internet I could only find a component only without pa/lna as in picture. I need only this one as in picture. Perhaps you have it?
Try this one
I think that has the external antenna. That part is old. @vanepp, you might want to run it through the checker, to see if it meets current validation.
Thank you for your reply. Unfortunately this module is without antenna. For my project a circuit with exactly the same modules as in life is very important, that’s why I’m looking for nrf24l01 + pa/lna.
There doesn’t appear to be one other than the one with the adapter board above. From a Fritzing point of view the one with the adapter board is identical to the one without (The pins should connect straight through.)
edit
That said this part should do what you want.
nrf24l01+palna.fzpz (9.8 KB)
Thank you so much, you’ve helped me a lot!!!
