1.) Drop two Camdenboss to your Breadboard. One will have 8pins the other 9pins.
2.) Switch to the PCB view. Try to build a bottom cooper line from PIN0 and PIN1 on the 8 pin Camdenboss. This is working. Try to perform the same on the 9PIN Camdenboss and you will fail, you can only do a top wire here, the bottom section is greyed out:
It should be possible to build a bottom cooper connection using a 9pin Camdenboss.
- Windows 10
- fritzing-0.9.10-l2134-40d23c29-win64.msi
Example_Sketch.fzz (2.9 KB)
Possible issue:
When I edit the 9Pin Camdenboss in the component editor it looks like there is no cooper bottom Layer:
Only the 8Pin Camdenboss has a cooper bottom layer
Workaround:
Use one 4Pin Camdenboss and one 5Pin Camdenboss. But maybe somebody can get that fixed in a future? ![]()
