Assuming you want to use this for 18650 batteries, the data sheet here:
has an appropriate layout (although it is for 18650s with internal protectors and thus likely needs to be 2mm shorter for non protected cells. A part with two clips and a battery in breadboard may be the better bet if you want to do a lot of them.
