AHT20 (Asair/Aosong)
Previous work, similar parts
There are at least a couple breakout boards for this part, but I could not find any for the component itself.
Adafruit AHT20 Temperature and Humidity Sensor
Seed Grove AHT20
I created an SVG image that is still readable at a smaller size. Perhaps this may be helpful.
The official documentation of the part manufacture is linked here (v1.1): AHT20 (English)
Possibly original version (1.0): Data Sheet AHT20
Temperature/Humidity Sensor SMD Component
I have not found any Fritzing part that is just the sensor component and not a breakout board. I am thinking that it would be pretty simple to put together since the dimensions and pinouts are very clear on the datasheet.
I think this is the last component I need to complete my first PCB in Fritzing. Thank you in advance for your help!
