I’ve done a search, and found that this was an issue with a posted solution about 6 years ago, but that solution is no longer available (as far as I can tell). I have a board under way with a MAX4468, and this has been a major hangup.
It looks like it got lost when the google repository shut down (along with many other parts.) There is a copy of the archive, but it is corrupted and unusable and no one seems to have a good copy. I’ll look at making a sot23-8 footprint in a bit (it isn’t particularly difficult for me.)
This should do what you need. As always before ordering boards print the footprint out at 1:1 scale and check it against a real part. DRC fails on 2 (but only two!) of the pins. Since they are all identical I can’t see why and the gerber output looks correct.
MAX4465.fzpz (6.5 KB)
Thanks! I’ll get right on working with this.
