Dimensions: 2 cm X 3 cm.
Can someone help me in making the part please?
Thanks,
Dena
Thanks,
Dena
This should do what you want. The size is somewhat suspect though. From a copy of the jpg on the web page 3CM by 2CM seems a little large, but as there are no measurements anywhere I can find, I used those.
edit: replaced part to change the dimensions to 2.5cm * 1.5cm
Garosa19tzg4n8kp.fzpz (9.9 KB)
You’re right, it is 2.5 cm X 1.5 cm. Could you please post an updated part?
Thanks so much!
Dena
Yes, the new dimensions look a lot more reasonable. The part has been replaced with a new version. You will need to delete minus the old part, then delete the part in your mine parts bin then shut down and restart Fritzing (to really delete the old part) before being able to reload the new part.
