Name
LM2941T
TO-220-5
Name
LM2941T
TO-220-5
This part should do what you want. Before ordering boards print the pcb footprint out at 1:1 scale and compare it to a real part. Verify the pins will fit in a 0.042in hole (they should although perhaps a little tightly) as there is no recommended pcb hole pattern in the data sheet.
LM2941T.fzpz (5.5 KB)
Thank you so much!!! That seems to be perfect!!! Great job!
