Need helpHow do I make a simple from 240vac step down to dc 120v,94v,75v,and in between volts to 1,5v Please help me
Please edit this message to let us know exactly what electronic part we are talking about. Creating parts is some work, so please be considerate and make it easy for us.
We need the title, an image and the technical data, fields are marked with a :red_exclamation_mark: . Without this infomation, the part can not be created.
Search the part prepare before posting.
You can search for the part here:
**Name of the part​:red_exclamation_mark:
<This picture shows the part from above, so that is easy to see were connectors should go, and which diameter they have.>
[R] Resistor (R)
Do I understand this correctly — you’re not looking for a part for the Fritzing software, but a hardware component, i.e. a power supply?
Is this a task you’ve been assigned, or do you actually need this power supply?
Best regards, Harald!
