I am new to Fritzing and I am trying to design a system for my model railway.
I am using above Modules as GPIO Expander with my Arduino Mega.
Has anybody designed this part???
Thanks
For future reference, pictures are basically worthless for making parts. What is required is a web site for the board that has dimension and connection information, in this case the Waveshare site here:
That said this part should do what you want. The connector on the right side does not appear in pcb as it can’t be connected to from the pcb.
Waveshare-mcp23017-module.fzpz (11.3 KB)
Hello Peter,
did you just make it on the fly? Where did you get the svg file from? I couldn’t find it on the developers’ website.
Great piece!!!
Harald!
Yes I made it from scratch, there doesn’t appear to be one anywhere on the net. I created the svgs from scratch (actually in the case of breadboard mostly via cut and paste from other parts, in the case of schematic from Randy’s Fritzing inkscape schematic extension and pcb from the breadboard svg.) I have a set of template files that I make parts from so it is reasonably easy for me.
