I found a suitable code that works for my Truck simulator but it needs modification and I need your help.
This code was ment for a toggle button. It has two functions:
1# Press short and print a given letter (e.g. “g”)
2# Press and hold and print a different letter (e.g. “g”)
What I need is simple: “When the input changes state, send the letter”
Please note: It shouldn’t cause a loop / string of letters. Remember this is a “toggle switch” and not a push button. So with every INPUT change, just send one letter at the time and wait for another INPUT change to send the same letter again without causing a loop.
Switch 1 should input letter “a” when ON
Switch 1 should input letter “a” again when OFF
Switch 2 should input letter “b” when ON
Switch 2 should input letter “b” again when OFF
Etc.
Ok, I found it with help of the Arduino forum. This topic may close.
Code for Arduino IDE to use PIN 2,3,4,5,6,7,8,9 and 10 as an INPUT with a PULL-UP 10k ohm resistor:
const byte switchPinA = 2;
const byte switchPinB = 3;
const byte switchPinC = 4;
const byte switchPinD = 5;
const byte switchPinE = 6;
const byte switchPinF = 7;
const byte switchPinG = 8;
const byte switchPinH = 9;
const byte switchPinI = 10;
byte oldSwitchStateA = HIGH; // assume switch OFF because of pull-up resistor
byte oldSwitchStateB = HIGH; // assume switch OFF because of pull-up resistor
byte oldSwitchStateC = HIGH; // assume switch OFF because of pull-up resistor
byte oldSwitchStateD = HIGH; // assume switch OFF because of pull-up resistor
byte oldSwitchStateE = HIGH; // assume switch OFF because of pull-up resistor
byte oldSwitchStateF = HIGH; // assume switch OFF because of pull-up resistor
byte oldSwitchStateG = HIGH; // assume switch OFF because of pull-up resistor
byte oldSwitchStateH = HIGH; // assume switch OFF because of pull-up resistor
byte oldSwitchStateI = HIGH; // assume switch OFF because of pull-up resistor
const unsigned long debounceTime = 10; // milliseconds
void setup ()
Serial.begin (115200);
pinMode (switchPinA, INPUT_PULLUP);
pinMode (switchPinB, INPUT_PULLUP);
pinMode (switchPinC, INPUT_PULLUP);
pinMode (switchPinD, INPUT_PULLUP);
pinMode (switchPinE, INPUT_PULLUP);
pinMode (switchPinF, INPUT_PULLUP);
pinMode (switchPinG, INPUT_PULLUP);
pinMode (switchPinH, INPUT_PULLUP);
pinMode (switchPinI, INPUT_PULLUP);
Keyboard.begin();
} // end of setup
void loop ()
// see if switch A is OFF or ON
byte switchStateA = digitalRead (switchPinA);
// has it changed since last time?
if (switchStateA != oldSwitchStateA)
oldSwitchStateA = switchStateA; // remember for next time
delay (debounceTime); // debounce
if (switchStateA == LOW)
Serial.println ("Switch A is ON.");
Keyboard.press(KEY_LEFT_SHIFT);
Keyboard.print("a");
Keyboard.release(KEY_LEFT_SHIFT);
} // end if switchStateA is LOW
else
Serial.println ("Switch A is OFF.");
} // end if switchStateA is HIGH
} // end of state change
// see if switch B is OFF or ON
byte switchStateB = digitalRead (switchPinB);
if (switchStateB != oldSwitchStateB)
oldSwitchStateB = switchStateB; // remember for next time
if (switchStateB == LOW)
Serial.println ("Switch B is ON.");
Keyboard.print("b");
else
Serial.println ("Switch B is OFF.");
} // end if switchStateB is HIGH
// see if switch C is OFF or ON
byte switchStateC = digitalRead (switchPinC);
if (switchStateC != oldSwitchStateC)
oldSwitchStateC = switchStateC; // remember for next time
if (switchStateC == LOW)
Serial.println ("Switch C is ON.");
Keyboard.print("c");
} // end if switchStateC is LOW
else
Serial.println ("Switch C is OFF.");
} // end if switchStateC is HIGH
// see if switch D is OFF or ON
byte switchStateD = digitalRead (switchPinD);
if (switchStateD != oldSwitchStateD)
oldSwitchStateD = switchStateD; // remember for next time
if (switchStateD == LOW)
Serial.println ("Switch D is ON.");
Keyboard.print("d");
} // end if switchStateD is LOW
else
Serial.println ("Switch D is OFF.");
} // end if switchStateD is HIGH
// see if switch E is OFF or ON
byte switchStateE = digitalRead (switchPinE);
if (switchStateE != oldSwitchStateE)
oldSwitchStateE = switchStateE; // remember for next time
if (switchStateE == LOW)
Serial.println ("Switch E is ON.");
Keyboard.print("e");
} // end if switchStateE is LOW
else
Serial.println ("Switch E is OFF.");
} // end if switchStateE is HIGH
// see if switch F is OFF or ON
byte switchStateF = digitalRead (switchPinF);
if (switchStateF != oldSwitchStateF)
oldSwitchStateF = switchStateF; // remember for next time
if (switchStateF == LOW)
Serial.println ("Switch F is ON.");
Keyboard.print("f");
} // end if switchStateF is LOW
else
Serial.println ("Switch F is OFF.");
} // end if switchStateF is HIGH
// see if switch G is OFF or ON
byte switchStateG = digitalRead (switchPinG);
if (switchStateG != oldSwitchStateG)
oldSwitchStateG = switchStateG; // remember for next time
if (switchStateG == LOW)
Serial.println ("Switch G is ON.");
Keyboard.print("g");
} // end if switchStateG is LOW
else
Serial.println ("Switch G is OFF.");
} // end if switchStateG is HIGH
// see if switch H is OFF or ON
byte switchStateH = digitalRead (switchPinH);
if (switchStateH != oldSwitchStateH)
oldSwitchStateH = switchStateH; // remember for next time
if (switchStateH == LOW)
Serial.println ("Switch H is ON.");
Keyboard.print("h");
} // end if switchStateH is LOW
else
Serial.println ("Switch H is OFF.");
} // end if switchStateH is HIGH
// see if switch I is OFF or ON
byte switchStateI = digitalRead (switchPinI);
if (switchStateI != oldSwitchStateI)
oldSwitchStateI = switchStateI; // remember for next time
if (switchStateI == LOW)
Serial.println ("Switch I is ON.");
Keyboard.print("i");
} // end if switchStateI is LOW
else
Serial.println ("Switch I is OFF.");
} // end if switchStateI is HIGH
} // end of loop
I also need help with my code to sync my switches with the ETS2 game upon start. I want Arduino to check the switch position of my dashboard and sync that with the game. Example: when my Light switch is on, I want the game to turn on the lights etc.
You should consider using arrays for the PINs so you can iterate over them (saves a lot of code).
You could even consider using one of the many Button libraries available.
Well despite its allot of code for just 9 switches, it does the job very well and reliable.
I started this code by using code from the many push-button with Debounce libraries out there. Please feel free to modify my code above and post it with your suggestion in it and I will try and post the results. I always prefer less code but code isn`t my once of my specialties.
