Need Help with a A7670e 4G-module
Hey everyone, unfortunately I have not yet found a similar board to this one in the forum. I would be really appreciative of your help in creating this part.
I really hope you can work with this. Thank you very much!
A7670E LASE 4G Cat 1 mit GSM GPS development core board A7670E-FASE A7670E-LASE
Bildschirmfoto 2025-04-29 um 06.31.38
Note: Both the speaker and the microphone seem to not be mentioned on this data sheet (They are labeled on the back in the bottom right corner on the development board.)
This part should do what you want. Pcb view has been suppressed as not useful.
A7670E-LASE-4G.fzpz (10.8 KB)
Thank you so much! I am a complete beginner so this helps out a ton!
Thank you very much for this part! I am also working with this module. However I Think the PCB view would be useful. Would it be difficult to add?
That would certainly be possible, but unfortunately the link to the datasheet is no longer up to date. Do you have a datasheet with the footprint?
Best, Harald!
Thank you! I noticed also that the old link is not working anymore. I found this link that at least have some of measurements of the board: A7670E LASE breakout kit PCB manufacturing PCB assembly-SMT Assembly-4g Module & Wireless Module Manufacturer-ANDTech
So the PCB view would just be a single THT row, like a pin header. I could go ahead and add that?
Best regards, Harald!
I once created a version with a PCB. Does this work?
A7670E_mit_PCB.fzpz (24.8 KB)
This works perfectly! Thank you very much for the help!
