Pintek Differential Probe DP-7500 7000V HIGH VOLTAGE INPUT
vanepp
March 21, 2024, 2:47am
2
Insufficient information here to ,make a part. No dimensions unclear connectors.
Dear Peter. Below is the link of the manual. You can refer to Page 15 - 17 (Model DP-100) for the specifications.
chrome-extension://efaidnbmnnnibpcajpcglclefindmkaj/https://d17bck4wpaw2mg.cloudfront.net/att/a/0/1/l/a01lu7/dp-manual-1.pdf
vanepp
March 21, 2024, 5:05pm
4
This part should do what you want. Note pcb view has been suppressed as not useful. Also the pin labels (other than the two input pin) are likely incorrect as there is no indication of polarity in the data sheet.
Pintek-DP-7500.fzpz (5.2 KB)
