It is also know as the adafruit ultimate gps. Is there a part that is already in the same package form as this? This is the documentation. https://cdn-shop.adafruit.com/product-files/1059/CD+PA1616D+Datasheet+v.05.pdf
I assume you want just the chip (as there is a Fritzing part for the breakout board on the Adafuit site?)
Yeah I just need the chip. I have to get this message to 20 characters.
This should do what you want. As always before ordering boards print out the footprint at 1:1 scale and compare it to a real chip.
edit: Forgot to add the hole in pcb. Part replaced with a new part so please redownload it. You will need to delete the old part and then restart Fritzing to be able to load the new part.
CD-PA1616D.fzpz (6.2 KB)
