Unfortunately the only computers I have access to do no have permission to install Fritzing. Can someone please help me create a very simple sketch of this sensor? I would be very grateful.
It is currently actual size (which is the Fritzing default.) That said yes it is easy to change its size in breadboard. If you provide the height or width you want I can make a reduced size part.
No worries! I figured it out, on a side note, do you know where I could find a 24V DC power supply with positive and negative terminals? I am going through the forum right now to find it as well
There are several including a set of generic power supplies which a search should find. Remember I need a value for the height or width to set the size of a reduced size part.
I have managed to resize the part and its perfect now! What do I search in the program to get the power supplies? Right now I am just getting random stuff when I search power supply
try “generic power supply” or “24v power supply” I think the 24V ones are large and closed frame, the generics may be what you want (although they probably aren’t 24V.)
