I need a male bug strip fzpz file
I have no idea what a male bug strip is, so a web site detailing the part you want would be needed to do anything. A google search for"male bug strip" turns up 0.1in headers which are available in core parts (assuming that is what you want):
drag a part in to the sketch then use Inspector (the lower right window) to set the various changeable parameters (for instance in this case from female to male.)
