Hi I need MS5540c Library
Insufficient information to do anything with (the template is in this group for a reason!) We would need a web site with physical dimensions and part layout and connector information to do anything (all of which the template asks for.) As well a google search of the form “fritzing part part_number” may turn up an existing part.
MS5540C datasheet(1/20 Pages) TEC | 6 coefficients for software compensation stored on-chip here is the data sheet
This part should do what you want. Before ordering boards print out the pcb footprint at 1:1 scale (printing should do that) and check it against a real IC.
MS5540C.fzpz (4.4 KB)
