I have created a breadboard layout, but unfortunately, having started in the middle, I have run out of space on the right side.
How do I select everything and move it to the left ?
In theory you can select all the components then move them on the breadboard. In practice Fritzing appears to select the breadboard as well and moves both which is useless. Perhaps someone else has a solution that works?
Try select all (control A) followed by control click on just the breadboard. Then drag the remaining selection. Not sure that will work but that is the ‘typical’ path. Otherwise it is select and move each part individually.
Not sure even that will move the wires. Safest is to make sure schematic view is routed, delete all wires on breadboard view, move the parts and add wires back again using the ratsnest as a guide.
