Miniatur-relais RPL RM85
Hello!
Has someone a part like RPL RM85 230AC 1 CO? (see RPL RM85 230AC: Miniatur-Relais 230 V AC / 16 A - 1 CO bei reichelt kaufen).
Thanks in advance
Nice regards
Manfred
This part should do what you want. Before ordering boards it would be a good bet to print the pcb footprint out at 1:1 scale and check it against a real part. The holes for the relay are set to 0.052in (~ 1.3mm) as specified and the spacing matches the datasheet.
relay-rm85-230AC-1-CO.fzpz (5.4 KB)
Hello Peter!
Many thanks for your support.
Nice regards
Manfred
