“Mini RS232 to TTL converter Module” (MAX3232 ESE+DN17) part available out of stock(approximately 9.4mm x 15.95mm).
I can’t find it as a fritzing piece. Where can I find it as part of fritzing(fzz or fzpz file)?
Please help me. Thank you.
This should do what you want. Note while the part has a pcb section, it is probably not accurate as it was made from a jpeg image. So you would need to print out the footprint at 1:1 scale and compare it to a real part before ordering boards. As well it has holes for all pins which the actual board does not.
mini_rs232_to_ttl_module.fzpz (5.6 KB)
You are indeed an excellent person. I admire you; congratulations. Thank you very much for your interest and information.
You have a nice way. God bless you. Good work, thank you.
