MiCS-4514 / SEN0377 part needed
Hi everyone,
I’m working on a project using the DFRobot Gravity: MEMS Gas Sensor (SEN0377 – MiCS-4514), which communicates over I²C and supports 3.3–5.5 V input. I’d like to include it properly in my Fritzing schematic and breadboard layout, but I can’t find an existing part for it in the Fritzing library or online.
Would someone be able to create a Fritzing part (.fzpz) for this sensor?
Key specs for reference:
• SKU: SEN0377
• Operating Voltage: 3.3–5.5 V DC
• Interface: I²C (0–3 V logic, compatible with ESP32, Arduino, Raspberry Pi, etc.)
• Pins:
1 – SDA (I²C data)
2 – SCL (I²C clock)
3 – GND
4 – VCC
• Dimensions: 27 mm × 37 mm
• Default I²C Address: 0x78 (configurable via A0/A1 DIP switches)
Product page: Gravity: MEMS CO, Alcohol, NO2 & NH3 Gas Sensor - DFRobot
Datasheet (PDF): MiCS-4514 / SEN0377 documentation
It would be great if the part included the Gravity-style 4-pin connector in the breadboard view and labeled the pins as SDA, SCL, GND, and VCC.
I plan to use this sensor with an ESP32 along with several other I²C sensors, so having an accurate Fritzing part would be a huge help for wiring and documentation.
Thanks a lot in advance to anyone who can help or point me to an existing model!
dfr-sen0377.fzpz (19.3 KB)
