Hi. I need MICS 2714 and 5524 parts for my project.
Presumably you want a breakout board for the MICS 2714, in which case you need to provide a web site with physical dimensions and connector information for the exact on you have or want. A google search for 5524 turns up watches so you would need to provide a web site for what you actually want. Such requests should be in parts help as well (which has a template for the necessary information.
The link is here : Amazon.com
Thanks for the file.
hi, can you upload the part “MICS-2714”? here’s the link : Fermion: MEMS Gas Sensor - MiCS-2714 -DFRobot Product wiki
This part should do what you want. Note the mounting holes are not drilled by default (they are only on silkscreen) so you need to drag a hole in to the sketch and place it over the hole in silkscreen and set the size appropriately.
dfr-sen0441.fzpz (6.3 KB)
MICS 5524 also is included in the Adafruit Library.
