I am a teacher an in school we work with the BBC micro:bit. We bought these kits FREENOVE Ultimate Starter Kit for BBC Micro:bit LINK
Now ti seems, that i can not use fritzing with the extension board from the starter set.
Now for me there are two question: Is anywhere a part for this extension board that I dindn’t find? Or do I have to think about bying another extension board if i want to use fritzing?
It should be easy enough for me to make a part for this. There are a couple of other breakout boards around but not this particular one it doesn’t appear.
This should do what you need. Schematic has pins overlaid to cut down on the complexity (technically they should all be overlaid, but I left the right side 5v and GND pins as it makes more sense to have them.) There is no pcb view as it isn’t useful.
