Meanwell - NLDD-1400H
LED driver
thanks in advance !
LED driver
thanks in advance !
Correct pcb footprint. You will need to delete the current part in your mine parts bin then shutdown and restart Fritzting (answering yes to save part and save bin questions) then restart Fritzing before it will let you load the new part.
meanwell-NLDD-1400H.fzpz (4.3 KB)
hi, thanks i will check right now…
as always super fast
hi i think meassure its wrong, can you modify please?
hi, sorry for asking again, its possible repair ? thanks in advance
It is repaired. The part was replaced a couple of days ago. Note the edit notes on deleting the old part.
let me check i didnt know it was upload again, thank you
The forum should have alerted you when I made the edit. I replaced the original part so there is only an accurate version in the forum not also an incorrect one.
