Hi. I’m looking for a fritzing file for 30Amp 5V-30V DC Motor Driver.
From Cytron Support:
MD30C.fzpz (90.8 KB)
You may wish to switch to this improved version of the above part. It lacks schematic and pcb and doesn’t have all the connectors implemented. The improved version does.
the power and motor connections don’t exist in the original.
Schematic was a copy of breadboard (which isn’t useful!)
pcb is probably slightly wrong in that the mounting hole positions are not documented and appear to be incorrect in the original breadboard (they don’t match up top to bottom or side to side!)
MD30C-improved.fzpz (26.7 KB)
That’s a lot of improvement ![]()
. Thanks man.
